oil filter location on c230
Old Mar 1, 2007 | 03:18 PM
gswcs02's Avatar
Default oil filter location on c230
ok so far you guys have been very helpful thank you! need a lil more help i have a 2005 c230 and i cannot for the life of me find the oil filter on it....if anyone has a photo of the engine and could highlight the filter location i would be extremely grateful...i can repay you for this info by discounts at circuit city since i am a manager there.
Old Mar 1, 2007 | 04:01 PM
chassis221's Avatar
Default RE: oil filter location on c230
under the engine cover on driverside either in the very back by firewall or same side still just toward the front but still under the engine cover.will need 27 mm socket to remove
Old Mar 1, 2007 | 04:35 PM
gswcs02's Avatar
haha im sorry im still not seeing it i dont think there is an engine cover on my motor i have the 4clyd kompressor motor
Old Mar 1, 2007 | 04:42 PM
chassis221's Avatar
maybe in front under cover, right by the dipstick on driver side its not a 27 mm thats an older motor but it is visible
Old Mar 1, 2007 | 04:43 PM
chassis221's Avatar
its kind of buried down alittle bit but it is there big round black thing like all benzs
Old Mar 1, 2007 | 05:06 PM
Trygve's Avatar
You are not looking for a traditional looking oil filter.
It is a long and thin black cylindrical looking tube. About 2 inches in diameter. It is in the engine bay about right central(driver side) and close to windshield end of the bay. It uncrews and lifts up and out and the filter is inside held in with o rings. The paper filters pulls off the end and you replace all the o rings which come with the new filter and slide the new paper filteron. I usually hand tightenmine and then a slight tighten with a wrench or socket.
Hope this helps.
Tryg
Old Mar 1, 2007 | 06:57 PM
gswcs02's Avatar
thanks guys ur the best i found it smaller than i thought and it has a large nut on top of it does anyone know the size wrench i need to buy to take it off with thanks guys so much
Old Mar 1, 2007 | 07:21 PM
chassis221's Avatar
27mm will work give or take. but i use 27 it was in the back right at fire wall??
ericnering
Dec 22, 2004 11:29 AM
ncipps
Dec 6, 2004 12:17 AM
omega
Jun 3, 2004 10:51 AM
omega
Jun 3, 2004 10:42 AM
hirsel18
May 27, 2004 11:29 AM
