Odometer stopped working. Help Plz.
#11
RE: Odometer stopped working. Help Plz.
Ok, still trying to figure this out. Any help would be greatly appreciated.
Here's what I've found out so far...
If I rotate the black wheel next the ones digit, it will turn the tripometer 1/10's digit and eventually the odometer's ones digit. There are little white "star" type wheels that turn each digit. If I can turn the little white star wheels with my fingures, the digits won't turn when I turn the black wheel next to the ones digit. Sorry I'm confusing, but I dont know what they're called.
Additionally, there's a white spiral-like rod behind the 40mph marking that's in contact with a black wheel attached to a rod that runs through the digits. I popped out the black wheel and rod that runs through the digits and turned it with my hand. It makes the ones digit turn.
My questions is, is the white star-like rod suppose to turn also? I couldn't turn it with my hand. It's the rod that's coming out of the back of the metal housing.
Please help if you can. THanks
#12
#13
I went to the site you mention (http://diymbrepair.com/. ) Shan and removed the panel under the steering wheel, but then it says to pull the odometer cable an inch or two through the firewall. what does the odometer cable look like? where is it? Thanks for your help.
#14
ORIGINAL: tygger
Hello everyone, I drive a 1990 300E and the odometer and tripometer on my car has recently stopped working. Everything else in the dash is working normally, but the mileage is stuck. It looks like it stopped in the middle of a change because some of the numbers are in transition.
Does anyone know if I can fix this myself? Do they even sell new odometers? If so, how can I buy one so it reads accurately because I don't want it to start at 0.
patricknif
03-04-2012 06:38 AM
CLK2000
11-19-2006 04:33 AM
