Not starting
Old Dec 4, 2013 | 06:00 AM
josisa's Avatar
Default Not starting
I have a 2010 R 350 Blue Tec.
Recently the car has decided to either turn on, or not turn on, depending on its mood. When I turn the key, the system is either 100% non responsive or the opposite. I think that there might be a problem with the security system. Any suggestions?
Old Dec 4, 2013 | 05:31 PM
chassis221's Avatar
it could be the ignition switch, very common issue on GL,ML, R, sometimes when turning the key it will start, other times turning the key does nothing, usually on the second try it will start. If you take it to a benz dealer, they can run it for fault codes. it will say something like "circuit 50" not detected, or some other EIS fault code. could also be a bad key/remote
omegabri
Nov 20, 2018 09:27 PM
ML63Colorado
Jun 29, 2015 03:06 AM
Paul Dalton
Feb 7, 2012 02:37 PM
red5jedi
Apr 23, 2010 03:26 PM
andrewandlorraine
Jan 26, 2006 03:14 PM
