Noisy in 1984 300SD on the expressway
Old Jan 22, 2006 | 10:33 PM
xlnc58's Avatar
Default Noisy in 1984 300SD on the expressway
It is hard to carry on a conversation in my 1984 300SD above 65 miles an hour on the expressway. Would silicone on the gaskets help or do you have any other suggestions?
Old Jan 23, 2006 | 12:13 PM
BlackWolf's Avatar
Default RE: Noisy in 1984 300SD on the expressway
What kind of noise, wind noise? Tire noise? engine? But from the little information I gather is that some seals are going bad and or are dried out. You are on the right track with the silicone. This most likely will fix the problem. And it's not hard or too expensive.
Old Jan 23, 2006 | 04:32 PM
xlnc58's Avatar
Thanks, It sounds like air noise around the back of the door at the top rear area of the window area. Is silicone for this purpose sold at auto parts stores? I just wondered if was a common problem. My wife and I have trouble hearing each other on road trips because the noise is so loud.
Old Jan 24, 2006 | 03:52 AM
BlackWolf's Avatar
it is a common problem on older cars, especially the ones over the 20 year mark. You should be able to get it through the general auto part store easy.
Old Jan 25, 2006 | 01:44 PM
C280 wizard's Avatar
I have the same problem with my 79 450SLC. All the weatherstripping around the windows need replacement. However I am doing them one at a time as the are very, very expensive. That is where wind noise usually comes from bad rubber or door panels not fitted properly, if replaced from accidents, rust, etc.
Lhaitzss
Mar 25, 2007 08:22 AM
getouttamyway
Oct 30, 2006 09:25 PM
ransford1994
Dec 28, 2004 12:35 PM
mespe
Sep 3, 2004 01:30 AM
mespe
May 20, 2004 10:46 AM
