No Heat in 1980 300SD
Old Apr 7, 2009 | 06:11 PM
jawsski's Avatar
Default No Heat in 1980 300SD
Not another dreaded servo issue because I replaced the original with the rebuilt aluminum body type a few years ago and has been working fine.
I recently filled with coolant cause system was low after sitting for a couple of weeks. Now I get no heat, not even on defrost setting. The recirc pump is working and the tubing to the heater core is warm to the touch but not as hot as it should be. All I get out of the vents is cool air at all settings.
Any ideas?
neneplaisance
Feb 11, 2010 08:59 PM
rayhawk43
Sep 1, 2009 09:45 PM
Dieseladdict
May 29, 2008 07:36 PM
michigan dave
Oct 8, 2005 11:47 PM
raspro7
Jan 31, 2005 01:14 PM
