No Dash Lights?
One of the black ***** sticking out below the speedo is a dimmer for the dash lights. It also dims the heater lighting and the gearshift light if its an auto. Try twisting the **** backwards and forwards, and it might start to work. The dimmer unit behind the **** usually oxidises a bit, but can sometime break too.
The dash is illuminated by 2 bulbs, that sits in the holders at the top of the back board.
You might access them by putting your hand under the dashboard and try to unscrew them, but not knowing what you are looking for, you'll fail.
Other way is to pull the whole cluster out. On this model it is much easier, than others. Push the cluster from the back couple of inches and using the 10 mm (?) wrench disconnect oil line to the gauge. Than you can pull it more and disconnect speedo cable and electrical plugs.
When you put it back, don't forget to connect the oil line back. Have seen few of those models on junk yard with interior filled up with oil.
slick1
Jul 30, 2007 07:05 PM
