Need CD Changer Info
Old Aug 1, 2012 | 11:28 AM
hooperdoski's Avatar
Default Need CD Changer Info
I have a 2006 SL500.
My CD Changer has been a problem for quite awhile. For the second time it has a CD stuck in the half way position so I get an error message saying the changer is unavailable.. Because of it I want to buy a new or used CD Changer. However, I'm concerned about whether or not it's as easy as installing it and playing it or does it require special steps like programing, etc to activate it. Can anyone tell me if there are any special steps that have to be taken after the new cd changer is installed in order to have it run properly?
Old Aug 7, 2012 | 12:07 PM
Bump.
Old Aug 7, 2012 | 06:33 PM
chassis221's Avatar
I can tell you that the cd changer is pretty dificult to remove. if youre talking about the one behind the driver seat..the whole rear area basically needs to come apart you can get to the changer but it just never seems to want to come out. its pretty involved...its not tlike the older cars where it can just slide out.
you can usually bang on the cd magazine itself fairly hard and at some point the disk usually will pop into place.
Old Aug 9, 2012 | 12:43 PM
I've taken the CD changer out before and it is the one behind the driver's seat. While it is labor intensive it wasn't that bad getting it out.
I have tried banging on the changer several times, but with no success.
Thanks.
trulegend
Oct 5, 2006 03:28 PM
AMGBenz
Jun 4, 2004 03:58 AM
mark191178
Feb 18, 2004 03:30 PM
firstbenz25
Oct 25, 2003 04:11 AM
