Mercedes Kempressor C30 2002 Problem
Old Dec 30, 2010 | 08:34 PM
melindamarrow's Avatar
Default Mercedes Kempressor C30 2002 Problem
i have a 02 mercedes-benz/c230k and the check engine light came on.i took my car to critz and they said vehicel won't accelerate or upshif,intermittently will not move in reverse or drive.when vichicel does move tranmission is slipping.performed a short test and found dtc's p2602,p2502,p22oa,all sensors reading in actullay vaules.all codes stored, whine noise intermittently head from bell housing area.and inspected transmission module and found no fluid present in wiring harnes,trans.fluid level overfilled and they recommend dropping the panto inspect for debris.this is everything they gave me on a print out. and i don'tunderstand it.can you please help me to know
Old Jan 13, 2011 | 12:07 AM
mbz_tech's Avatar
I would say you have engine coolant leaking into you transmission. Good luck with that.
rorymcmillan88
Apr 4, 2012 08:54 PM
hellombowners
Jan 7, 2010 08:10 AM
rsmith1222
Dec 2, 2008 10:04 PM
alinux
Sep 26, 2008 01:01 PM
AllBizNiz
Sep 2, 2005 07:42 PM
