Leaking Oil Gauge
Old May 3, 2008 | 06:03 PM
moondoggy's Avatar
Default Leaking Oil Gauge
I have a 1982 300D Turbo. The oil gauge is leaking badly to the point where it is dripping over my pants now. I tried to tighten the connection, but I do not think that is where it is coming from. Appears to be coming from the instrument panel.
Is there a way to plug the connection at its source thus disabling it and stopping any further oil leaks inside the car? Where is the connection located on the block? Is it accessible and what kind of plug would I need to plug it?
Old May 4, 2008 | 12:31 AM
lwbrewer's Avatar
Default RE: Leaking Oil Gauge
This sounds after market my 87 is all electric, but temporary you can use a 1/8" npt plug to plug it at the engine use tef tape or pipe dope on it. Most likey you have 1/8" tubing going to your gauge it may be loose at the gauge or the tubing has cracked/ split. You can get new tubing at the auto parts and new ferrules. Use the old tubing to pull the new threw the fire wall or switch to electric and keep the oil out of the passenger compartment
one
Apr 20, 2012 02:06 AM
ddtbreakfast
Apr 21, 2008 11:34 PM
franko
Jun 24, 2007 12:54 PM
jenrey
Oct 22, 2005 01:18 AM
jab
Apr 17, 2004 10:22 AM
