Key won't turn at all
Old 02-08-2006 | 01:25 PM
chud's Avatar
Default Key won't turn at all
Ok, so I get in my 1982 Mercedes 300 SD this morning, insert the key in the ignition, and it won't turn. I remove the key several times and reinsert it, but it just won't turn at all. It's like it is stuck. I had to take my other car to work. Anyone seen anything like this before?
Old 02-08-2006 | 11:40 PM
Lugnut's Avatar
Default RE: Key won't turn at all
Is the steering wheel just bound up with the steering wheel lock? Have you tried turning the steering wheel a little bit in both directions while trying to turn the key? Use a bit of force.
Old 02-09-2006 | 01:02 AM
jnolte's Avatar
yes try turning the wheel back and forth while inserting key.
if not you problay need a new lock tumbler and its going to have to be cut out
Old 02-09-2006 | 05:27 PM
chud's Avatar
ORIGINAL: jnolte
That's what my mechanic told me. I am hoping I can get the key to turn one more time, and if I do, I'm going straight to my mechanic and he can fix it. If I can't get the key to turn, I'm going to have to get it drilled and a new lock tumbler installed.
Old 02-09-2006 | 05:39 PM
mbz300sdl's Avatar
If you get the key to turn one last time u won't have to drill it to get it removed. They make a special tool for Mercedes to remove the tumbler.
www.performanceproducts4benz.com
part numbers
58-045
58-046
Old 02-10-2006 | 07:28 PM
teddybear's Avatar
I have had same problem on a 1989 W124 260 E. The keys tend to wear with time. I just ordered a new key by chassis number from my MB dealer and it fitted perfectly. Cost about £10 much less than a new lock. Obvious question have you tried the spare key or Chauffer key if you have one.
Old 02-11-2006 | 02:21 PM
C280 wizard's Avatar
I had this problem with the 79 450SLC I bought recently I cured it with graphite dust into the ignition. works fine now.
jazharp
05-25-2016 10:30 AM
ddilillo
09-18-2008 10:12 PM
cjarrett
11-01-2007 11:25 AM
wishstar
07-27-2005 08:43 PM
