Key Problem - 1986 500 SL
Old Jun 19, 2007 | 05:01 PM
RogHyde's Avatar
Default Key Problem - 1986 500 SL
My key is stuck in the ignition - in position 2 - it will turn clockwise from there but not back to zero so I can't remove it and the immobiliser prevents the engine from starting because it has to start from zero!
I think it may be the cable from the park position to the ignition switch but how do I locate it - does it come from the gear stick or on top of the gearbox and how do i remove the trim to get behind the ignition switch if the problem is that end.
Any advice will be much appreciated.
Old Jun 20, 2007 | 12:23 AM
snanceki's Avatar
Default RE: Key Problem - 1986 500 SL
Have you tried moving the gear lever out of "P" and back again incase it didn't quite engage in "P".
If this doesn't work then I agree with you analysis and would suggest that the gearbox position switch is out of adjustment.
I believe (not familiar with pree 1995 MB) that this will be connected electrically.
Stuart.
RogHyde
Jul 25, 2007 03:40 PM
benz300e
Nov 26, 2006 01:48 PM
benz300e
Nov 23, 2006 03:26 PM
franklinjb
Oct 7, 2006 03:31 AM
korte4260
Apr 1, 2005 04:27 PM
