Intermitant Power Seats problem
I dont think it is the switch. when they stop working, the passanger side stops also even if I use the passanger seat swtich. Is there a relay or some thing that could cut off power to both seats at the same time?
sound like the K24 is malfunctioning.
go check if power is okay, fuses not loose. check for any corrosion.
what's the other symptoms?
[IMG]local://upfiles/1/2589F42BB7CE4421AD213BF8EF1FF06B.jpg[/IMG]
In your picture it looks like there are 2 relays close to eachother, well i only have one in that area and i pulled it out and pluged it back in and the seats work now. I hope it will stay working for a bit and its not doing its intermitant BS again. Thank you all for your help.
boycie
Feb 15, 2011 09:30 AM
sdunham
Dec 27, 2006 07:23 PM
