Instrument Cluster Failure?
The gear display and clock in my 2000 clk230k seems to have sections missing which means it is unreadable, like the pixels arent working.
Is there anything i can do to fix this problem?
I think something is loose or has a bad connection as i can give the display a whack and it will be fine for a while before going off again!
Help!
Help!
hello. i have mercedes c220 cdi, i had the same probelm. I fixed this by stripping the clocks until you see the electrical ribbon going from the display to the curcuit board, Mine have three of these. I sprayed contact cleaner followed by compressed air along the contact. This has fixed the problem, although i had to do it three times.
hope this helps
michael
hope this helps
michael
jerzstyle00
Apr 22, 2011 10:05 PM
lxshk
Aug 7, 2008 08:28 PM
rich121
Oct 7, 2005 09:40 PM
