IGNITION FROZEN 92’ 190 2.6
Old Feb 14, 2004 | 11:41 PM
PFSKIER's Avatar
Default IGNITION FROZEN 92’ 190 2.6
Lookin for general info on how to remove the old tumbler. Ordered the new one but having no luck finding info on how to remove the old one that is frozen in. Turned the face of the old tumbler to get a pin in to release but the outside black colar won't allow me to remove the tumbler. Any help would be much appreciated. Is there a lock on the outside colar as well? Do i cut it off? Dealorship is too far away, unfortunately.</P>
thank you</P>
Paul</P>
Old Feb 14, 2004 | 11:51 PM
myamg's Avatar
if you can not get the lock cylinder in to postion 2 (2nd detent) then you will </P>
have to drill out the lock tab that i beleave you were talking about. It is a pain it the butt and could take a while... good luck</P>
Old Feb 14, 2004 | 11:58 PM
PFSKIER's Avatar
So even thou I am able to turn the face of the tumbler to get to the release mech on the tumbler doesn't matter, I have to be able to turn the whole key to position 2, which isn't happening. The "hub" that holds the tumbler in, how does that piece come off?</P>
Your help is much appreciated on this project.</P>
Paul</P>
What size bit, and what is my goal of drilling out the tumbler, is there a release in there that allows me to remove the outter hub?</P>
thanks again</P>
Old Feb 15, 2004 | 12:27 AM
myamg's Avatar
no do not drill out the hole tumbler there is a lock pin release that u have to drll out if u would be able toturn tumber to 2nd postion this would release the lock pin and since u cant do so u have to drill it out and that will allow you to remove out hub andlock cylinder, </P>
basicaly u would tuned the tumbler to 2 then you would press in the lock pin(thats what ur drilling out) then u would rotate the "hub"towards front and wiggle it until </P>
it comes out the "hub" and out with the tumber </P>
good luck let me know if u need any other help, maybe even a dig pic it you need it pointed out</P>
good luck
</P>
</P>
Old Feb 16, 2004 | 10:49 PM
PFSKIER's Avatar
Well with your help we have did it. However, we tried to turn the car over withno tumblers and it seems to be locked?By taken a screwdriver and spinning it, but it doesn't turn at all? So out from the pan and into the fire I go. What would be causing the problem if its not the tumblers? i am sure I am testing your knowledge at this point in time, as for me a i am clueless. Maybe steering column, or tranny?</P>
</P>
Thank you for your previous help it was much appreciated.</P>
Paul</P>
Old Feb 17, 2004 | 12:30 AM
myamg's Avatar
that sucks it is allways the tumber did u try to install tumber and see if it is still locked up????maybe it has to have the tumber installed, is your steering wheel locked???? if it is locked i dot think a screwdriver would turn it over???
Fine420SEL
Sep 8, 2006 01:05 PM
sushi
Jan 5, 2004 08:37 AM
EuroAddict
Dec 11, 2003 01:24 PM
Rick
Dec 6, 2003 01:55 PM
Midknight
Dec 4, 2003 02:58 AM
