idle adjust, tranny, 75 300d
Old Dec 5, 2006 | 11:27 PM
lawrgj's Avatar
Default idle adjust, tranny, 75 300d
where do i get a new idle adjust cable and is it neccesasary, also does anyone have any idea what to look out for? and jeez sorry,,, but my transmission wont engage unless i let the car warm up for about 30 minuits
Old Dec 7, 2006 | 05:32 PM
carnut's Avatar
Default RE: idle adjust, tranny, 75 300d
The idle cable is in reality a cold start idle up cable. Turning it counterclock wise prior to starting in cold weather enables the engine to run faster and warm up quicker. Here on the left coast I very seldom use mine. If I do use it, its for a slightly higher curb idle with the A/C on. In areas that see snow and sub zero temps then the cable is a nice addition to help start it. Regarding the trans, change the trans filter and all the fluid. The torque converter is drainable unlike other cars. DO NOT have it flushed. Can cause particle contamination on any older car. Uses common DEXTRON fluid.
techbot
Sep 10, 2009 08:04 AM
cjaye
Feb 26, 2008 04:00 AM
duvan
Feb 15, 2008 08:30 PM
bigpauly52
Feb 22, 2007 07:59 PM
nickydubs
Nov 26, 2004 11:20 PM
