i must be stupid!
i must be stupid!
i have a 99 c280 sport and i need to change the front brakes. i don"t have alot of experience with brakes but i can"t seem to get the caliper off the rotor. i took off the dust caps and unscrewed the 7mm hex head bolts and removed the retaining spring on the caliper , but it still won"t come off, just wiggles a little bit. it's probably something simple but for the life of me i can"t figure it out. the brakes on the back were sooooo much easier to do. thanks for all the help u guys give me.
You do not have to take the caliper off to change the pads!
But if ya gotta change the rotors, compress the pistons with a screwdriver. I bet the pads are simply getting stuck on the ridge. And if you have a ridge, then you probably need rotors.
