Help needed now-5.6 into 380SL
Old Apr 20, 2007 | 08:02 PM
childressj's Avatar
Default Help needed now-5.6 into 380SL
I am trying to complete a 1986 5.6 L (117.968) into 380SL (107.045) and down to connecting engine electrical. 5.6 harness from sedan does not interface well with 107 chassis. Does anyone know where I can find a 560SL engine electrical harness?
Will a person with detailed knowledge of the difference between the 2 engines please advise if I can use the 380 fuel distributor in addition to the 380 ignition distributor to solve the problem. If it involves some compromises but will work OK, Iwould be willing to live with it untill I can make up a harness.
Thank you very much.
Jim
Old Apr 24, 2007 | 07:01 PM
irantehran's Avatar
Default RE: Help needed now-5.6 into 380SL
it may work well if it all line up , make sure you have a new oooo ring ,the dif f is in engine capacity , one may have a in line fuel transisttor ccheck all that
flainn
May 2, 2012 10:55 AM
davidmlee
Jan 21, 2009 05:23 PM
DrTris
May 21, 2008 10:52 AM
castman
Sep 25, 2007 01:28 AM
Dehaven
Oct 16, 2006 11:21 AM
