Heater blower on 190E
Check your fuses first.
The blower motor is located under the hood. You'll need to put the hood completely vertical to get access. The wiper assembly has to be removed to gain access. Beneath the center of the windshield is the black plastic cover for the blower motor assembly, held in place with metal clips. Undo the clips and and remove the cover.
Theres also a fuse located in the back of the climate control unit. Inspect that. A defective climate control unit or a defective blower switch can also be a possible why they blower motor isnt turning on.
Problem solved!
Applied the battery directly to the blower motor and it whizzed into life, reconnected it and it worked fine after this!
Turns out the connections were dirty and oxidized, just filed them clean.
Thanks for your help Dan
necompressor
Jan 18, 2005 06:06 PM
