Having trouble uploading
Old Oct 11, 2011 | 08:02 PM
robcaven58's Avatar
Default Having trouble uploading
Can't figure out how to upload photos of my car from android phone
Old Oct 12, 2011 | 08:25 PM
chassis221's Avatar
I have the original motorola droid that first came out 2 yrs ago and it works to upload to my gallery, i did have an issue at one time where it seemed the site when using my phone something wasnt compatible. I had a hell of a time trying to upload an avatar. But I did just now upload a new pic to my album , from my droid and it worked.
Old Oct 17, 2011 | 12:44 PM
robcaven58's Avatar
Thankyou, chassis221. I'll keep trying.
Old Oct 22, 2011 | 11:05 PM
robcaven58's Avatar
Still when I try to upload pics, it says uploads disabled. How do I change this setting?
Old Jun 29, 2013 | 01:43 PM
300SEL's Avatar
Default few posts
since there is only one moderator here and nobody in charge, I'll take a stab at this.
There may be a restriction, because you have so few points/ are fairly new here....
Alex
Old Jul 7, 2013 | 01:45 PM
Nancyronniel's Avatar
Location of rainwater drains on 2000 S500? Can these be easily cleaned by owner? Does the manual recommend these be periodically pressure cleaned by dealer? Thank you .
Ronnienancyl
Old Jul 7, 2013 | 03:23 PM
chassis221's Avatar
Ronnienancyl
on the 2000 S class the drain under the hood on the passenger side firewall get clogged up and water will get into the vehicle passenger side floor. That's usually how water gets in those S classes.
there is a procedure to clean the cowl below the windshield but that is only performed on the B services. Generally its the customers responsibility to maintain the cowling and keep debris from building up and clogging the drains.
Old May 13, 2015 | 04:17 PM
96SL500's Avatar
From: Manatee County, Florida- Sarasota mailing address
Default Uploading pictures to album or garage on this site
I have tried to drag and drop and copy and paste. My pictures are on large albums on my desktop computer. Any idea how I might upload 1 or 2 or 6 pictures?
Old May 14, 2015 | 09:56 AM
  #9
pncurtis's Avatar
Sometimes there is a limitation on the size of the file you can upload. Inquiring about that size limit may help solve your issue because you can then adjust the physical size of the file to comply.
Paul Curtis
Old May 16, 2015 | 09:18 AM
  #10
96SL500's Avatar
I didn't mean I had a large file to upload, only that my vehicle pictures are within large albums. I would like to upload only a few pictures. For instance, my garage, and my main MB vehicle. If you have a clue on how I might do this, it would be welcome.
gus_carrero
Jul 10, 2007 03:35 PM
kyoujin
Oct 21, 2006 08:43 PM
thdesigns
Jul 2, 2006 07:18 PM
Nov 15, 2004 05:40 PM
kompressorboy8
Mar 17, 2004 03:42 PM
