hard starting
Old Sep 5, 2005 | 09:37 PM
TBenedikt's Avatar
Default hard starting
I have a 1984 380SL which runs great most of the time. On occasion after you shut it off the car just will not start. I have replaced the fuel pump and fuel pump relay. The car has new plug wires, cap , and rotor. If you let the car sit for a while it starts fine again. I need some advice as to what to do to fix this annoying problem.
Old Sep 5, 2005 | 10:25 PM
sleepwalker's Avatar
Default RE: hard starting
did you check for leaky fuel injectors?
check the resistance of the crankshaft position sensor whenever the problem is present. (800-1200 ohm).
tarrantb
Dec 3, 2010 01:25 PM
aharley1
Mar 27, 2005 03:14 AM
volksoholic
Feb 3, 2005 10:18 PM
alex002
Dec 22, 2004 09:43 PM
az300e
May 18, 2004 07:02 PM
