gas
Old Nov 12, 2008 | 12:11 PM
deseraligears's Avatar
Default gas
have an 89 300 te mercedes disclaimer staes use high octane gas when filling car? or premium if you will . As this is an 89 was the gas back than on the regular pump not as good as todays? Or should I use premium do you not the octane limits? On another issue filled tank yesterday and today I smelled gas looked underneath and gas is leaking from hoses coupling or the round silver cylinder near tank. Never saw this before , as I do not have a manual i was wondering if this problem that one sees over the years I have never had it this is my second wagon! Maybe its just a tightning cannot get under to actualy see but it started after fill up? Thanks in advance
Old Nov 12, 2008 | 08:03 PM
jimandsuzy's Avatar
Default RE: gas
I've always used 87 octane regular in my 85 380SE. I had to replace the aluminum washers on the fuel pump banjo bolt because of leaking. I went to the local parts store and found some generic washers that fit.
cam69ss
Oct 25, 2004 02:45 PM
jigsaw1975
Feb 9, 2004 07:23 PM
11margie
Jan 9, 2004 04:13 AM
CRedRun
Jan 3, 2004 08:29 PM
fuer
Dec 22, 2003 01:37 PM
