Garage Door transmitter
If you've tried everything and you still can't get the garage door to open, it could be that the transmitter from the car is fine and the one on your garage door is faulty. If you are certain that both transmitters are fully functional, try using a different code. This will eliminate any possible problems caused by a code conflict. If this solves the problem, then you know that the problem was related to your original code. If this doesn't solve the problem, try replacing the receivers on each of your locks by contacting a garage door repair Calgary expert.
