Fuel requirements
Old Apr 27, 2004 | 09:45 PM
  #11
Lugnut's Avatar
Default RE: Fuel requirements
Do you hear an echo in here?
Good info. about octane numbers. I know Flyingphil is from down under. That's why I made the comment about aliens' comments. He never explained all this RON-MON stuff, nor did he even bother to divide what he said by 2.
Old Apr 28, 2004 | 09:23 AM
  #12
Flyingphil's Avatar
Not exactly sure how octane is Measured in Australia. But here (by government legislation), unleaded has a minimum rating of 91 octance, lead replacement 96 and premium unleaded 95. Shell and Bp offer special premium unleaded which has 98 octane which I find makes my car take longer to start.
Old Apr 29, 2004 | 10:50 PM
  #13
Lugnut's Avatar
Here's some gasoline trivia that may win you a drink during your favorite saloon's happy hour.
Question: Which grade of gasoline is more volatile, regular or premium?
Answer: Regular.
In order to help prevent engine pre-detonation (or pinging or pre-ignition) premium gasoline is used because a higher temperature is required to ignite it versus regular gasoline. Regular gasoline can cause pre-detonation because it ignites at lower temperatures than premium gasoline. Pre-detonation occurs when the gas/air mixture in a combustion chamber ignites before the spark plug in that particular cylinder glows. Most commonly, the pre-ignition is caused by glowing carbon buildup in the combustion chamber or by hotter running high performance engines.
The higher the gasoiline's octane rating, the higher the ignition temperature must be to ignite it. That's why racing gasoline has such a high octane rating. Racing engines run very hot. But they also have extremely high-voltage ignition systems to ignite the high-octane gasoline. That's why you don't want to waste your money on premium gasoline if your engine doesn't need it.
Old May 22, 2004 | 12:31 AM
  #14
RTS3GEN's Avatar
ORIGINAL: Lugnut
Answer: Regular.
There are also far more impurities in the lower grade fuels and thus can catalyze preignition. Do the math. For a 15 gallon tank of 87 at 1.90 that's 28.50 for a tank(provided the tank is empty) for the gas the computer and engine calls for is 2.10 per gallon, that's only 3 dollars more per fillup! Less than a 16OZ bottle of beer on Friday Night!!!!! Is it really worth risking engine damage or failure for 3BUCKS? Just my thought.
Art
Old Aug 13, 2004 | 12:46 AM
  #15
Lugnut's Avatar
Huh? I think your calculator needs fresh batteries. The difference is $4.50 per tank in your example. Do the math. That's if I understand what you're saying, which I don't think I do. I think you maybe misunderstood something I said?
Also, this phrase makes almost no sense to me because of the alien-like grammar:
For a 15 gallon tank of 87 at 1.90 that's 28.50 for a tank for the gas the computer and engine calls for is 2.10 per gallon ...
Anyways, what factory car(s) in America is designed to run only on 93 octane gas, or even 92 octane? Arrrrrgh! Wrong! You can't get 93 or 92 octane gas everywhere in America (lower 48). Are MB cars sold in America geo-centric? Nope.
Old Aug 13, 2004 | 01:19 AM
  #16
Shan's Avatar
Very informative and enlightening discussion we have had here.
But let us stick to the premium grade for our dear MBs.
I use premium for my 1979 MB200 and my PONTON MB180.
They give me good performance.
Old Aug 13, 2004 | 06:08 AM
  #17
Lugnut's Avatar
If every MB owner used premium-grade gas, then many MB owners would always be wasting their gas money. Premium gas doesn't "give" performance at all. It prevents a loss of performance by preventing pre-detonation. That's because high-grade gas is less volatile than low-grade gas. Hello?
I can understand why your higher compression '67 might need premium (actually leaded) gas, but something is wrong with the '79 if it needs it. Either that or you have a foreign-spec MB that doesn't mirror US smog requirements so maybe it does need premium.
dengineer54
Jul 20, 2010 07:17 PM
KANEGRANT
Dec 30, 2006 02:45 PM
jdorencc
Nov 18, 2006 05:27 PM
dalbertog
Jul 7, 2006 11:47 PM
kazacs
Sep 22, 2005 05:42 PM
