Fuel pressure sensor
Old Feb 24, 2008 | 09:33 AM
michael27's Avatar
Default Fuel pressure sensor
I have a 2001 Mercedes c320 and I need to know the following. On top of the fuel pump there is a pressure sensor. Does this sensor detatch or would I need to replace the entire fuel pump?
Old Feb 24, 2008 | 10:38 AM
chassis221's Avatar
Default RE: Fuel pressure sensor
the whole unit will need to be replaced i believe. there are no detachable parts on the fuel pumps. there is a fuel pressure regulator built into the fuel filter.
Old Feb 24, 2008 | 06:17 PM
michael27's Avatar
Default codes
Hey thanks. Can you help me with some codes? P201C, P0450, and P2010. Also, my BAS indicator light came on the same time my cruise control stopped workng. Do you think it may be a switch under the brake pedal?
Old Feb 24, 2008 | 10:07 PM
chassis221's Avatar
Default RE: codes
yes good possibility
Old Feb 25, 2008 | 12:06 AM
michael27's Avatar
Default RE: codes
my check engine light is on and had the car "read" and the code p201c said i need a fuel canistor pressure sensor. The mercedes place sent mea sending unit and wont give me my money back. just wanted to make sure i needed a fuel pump to correct the problem. ur info is greatly appreciated
newport5
Sep 12, 2008 12:19 PM
hughits
Jun 24, 2008 02:19 PM
empi123
Jun 10, 2007 11:31 AM
mr2weenie
Jul 10, 2006 04:21 AM
techteam
Sep 27, 2005 12:43 AM
