fuel injector cleaners
Old Apr 24, 2004 | 06:00 PM
megamerc's Avatar
Default fuel injector cleaners
hi
I have a 2003 ml 350 with 8800km on the clock.When should I start using a fuel injector cleaner?
Old Apr 24, 2004 | 06:12 PM
GermanStar's Avatar
Default RE: fuel injector cleaners
I don't know that I'd use it all, but I would even think about it for a long, long time.
Old Apr 24, 2004 | 11:56 PM
SANDDOG's Avatar
HI Megamer, I would every couple of 1000's mile. There is water in the fuel, it's a great way to help it pass without damaging the injector tips. Especially if you live in a wet area. The valves like it too. However use with at least 20 gal's of gas, the additive can be hard on the rings.
Old Apr 25, 2004 | 10:01 PM
Buck's Avatar
I have used RED LINE fuel conditioner with great results I think. That is one of the things you hardly know if it works or not. They have a diesel fuel "catalist" that I know works great, cuts down on the smoke and clatter is reduced too.
Old Apr 26, 2004 | 12:03 AM
SANDDOG's Avatar
Also Chevron Techrolean (not sue about spelling) was rated by car & driver as one of the best gasoline injectors cleaners on the market. Prices though $$$$$$$ good luck
Old Apr 27, 2004 | 09:31 AM
Lugnut's Avatar
If you use the cleaner-in-a-can don't wait too long. It's just a light duty cleaner and can really plug an injector if it dislodges a gob of something.
A well-supplied mechanic can clean the injectors. They force cleaner through the injectors under pressure. But wait longer to get it done.
I would do the latter.
Fixit
May 17, 2008 11:55 PM
Brndnb02
Oct 9, 2007 11:32 AM
gotthebenz4
Nov 6, 2006 10:03 PM
tampa230
Aug 10, 2006 11:30 PM
w.neurauter
Sep 8, 2005 08:10 AM
