Front windows quit working
Old Dec 31, 2007 | 10:10 AM
Tasma's Avatar
Default Front windows quit working
The front windows in my 1999 E300 quit working. Also the front power seats and mirrors quit at the same time. There is no fuse common to all these items so I think perhaps a ground wire has broken.
I need to find out if there is a common ground circuit for these items or could it be something else? Fuse #3 is common to the front two windows as well as the back windows but they work fine.
Old Jan 2, 2008 | 11:54 PM
gtivw1992's Avatar
Default RE: Front windows quit working
HI ck the fuse for the door control module
Old Jan 5, 2008 | 04:15 PM
ghenry's Avatar
I have a 1999 C230 Kompressor, same problem, did you find out what the problem was?
Old Jan 5, 2008 | 04:44 PM
Tasma's Avatar
I have not yet found the problem. The other day everything started working again. Today everything is dead again. I noticed that the FOB will not lower any of the windows or sunroof even though the back windows work as well as the sunroof from the switches inside the car. This leads me to believe that the problem is in the module in the drivers door. I can’t find a fuse that says it is for the any of the controllers.
This car is going to be a large pain in the rear if more things fail.
Old Jan 9, 2008 | 11:17 AM
Tasma's Avatar
The problem goes away for a while if I disconnect the battery for a short while. A few days later the problem returns.
Old Jan 16, 2008 | 01:28 AM
djnevoc's Avatar
Just a thought... My passenger front door was having an issue going up and down. Sometimes if you cloesed the door like a guy it would work, but my wife never shut it hard enough to get it to work. Today I did some maint on the car and noticed on the door that there are 2 hinges and then a center hinge. The center hinge was very loose. No other doors were like this so I tightened it up and now the window works fine.... I wonder if that center hinge works like a ground?
NeV
Old Jan 29, 2008 | 12:12 PM
ghenry's Avatar
Thanks, mine are all working fine now. I had my better half spend some time with it. But I have no doubt that there is something loose/short/or sensitive.
bobjohnson2121
Mar 16, 2014 05:52 PM
mcastell
Nov 30, 2010 10:00 AM
retownsendjr
Aug 11, 2010 08:30 AM
UncleMarkProductions
Jan 24, 2008 07:55 PM
herbman
Jan 28, 2004 09:01 PM
