Engine won't turn off with key
check your vacume line from the air pump to the back of the ignition key ,on the back of the ignition cylinder there is a vacume switch ,you must have vacume at that switch when you turn off the motor,
also on the top of the injection pump in the back of it there is a vacume diafrugm when you trurn off you must have vacume to that line ,to see if that unit work turn your key off put a vacum hose there and with your mouth suck on that vacume line it sholud turn the car off if not replace that unit,
Chuy73
Aug 16, 2011 09:23 AM
fastmike99
Oct 28, 2006 04:21 PM
