Engine does not run!!!!
Hello all
would you help me To find the problem with my engine. it does not run
I have Replaced the fuel pump & Filter this This morning every thing were okay but after One mile engine go off . i check spark plugs fuel supply
The whole works
but engine still not working .
one more thing : I replaced the original filter with ( mazda 626 ) one .
The whole works
It's frustrating when your car will not start - it happened at least once a majority of drivers. I even had situations where my car would just decide to call a sick and would not start several times. You turn the key and ... nothing happens. There are many things that can go wrong, but there's no reason to panic, is the solution to almost any problem, it just is not always easy to find.
Hopefully this article will help you to find out why the car does not start and if not, then this information will help you better explain your problem mehaanikud.Vaga detailed description will help your mechanic diagnose the problem faster.
Jopenko1
Dec 10, 2012 03:18 PM
digieditny
Oct 4, 2010 02:53 PM
87MBZTurbo
Aug 30, 2009 06:06 PM
Bullish
May 10, 2009 12:31 AM
