electric windows 1982 380sl
Old Sep 5, 2006 | 11:11 PM
Sandi's Avatar
Default electric windows 1982 380sl
Both electric windows simply stopped working. The fuse checks out ok. Any suggestions? Thanks
Old Sep 6, 2006 | 03:36 AM
snanceki's Avatar
Default RE: electric windows 1982 380sl
BOTH (LH and RH?) simultaneously!
Sure you got the correct fuse? this is the only component common to both circuits that I can think of.
If you are DIY competent check voltage at each end of the (correct) fuse to ensure the supply is OK.
If this is OK you will have to measure voltage at various points in the circuit. next suspects are SWITCHES and RELAYS but two circuits would not normally go down together.
Stuart
toadjuscuz
Jan 12, 2008 08:09 PM
C280 wizard
Sep 6, 2005 09:56 PM
milo200
Sep 2, 2005 02:04 PM
muggsy
Feb 25, 2004 07:40 PM
ballyhoo1
Feb 25, 2004 12:59 AM
