E320 will not start
Old May 8, 2005 | 09:47 AM
MBraven's Avatar
Default E320 will not start
Hello from a newbie.
My mercedes E320 Wagon, has recently had problems starting. It seems like the fuelpump will not go, so I changed it. It was better for awaile, but the it started again..no fuelpump going.
Today it would not start at all, but the fuelpump was working, and I heard a relay working like hell, and some noises from injection, like airpressure comming out.
I opened the place, a box on the middle of injection tubes, inside it was a vacuum regulator, that moved and get stuck and fastened at a point. Had some lubricant on it and it is now moving easily,
I found the relay numbered: 003 545 56 05, [04] 6 zyl. KLI/KD, and it was working all the time.
I took it out and could see that it has been opened before, and sealed again.
Could this relay be the problem? Or else what is it.
I'm quite frustrated at the moment, so thanks for any help.
Old May 8, 2005 | 12:07 PM
sleepwalker's Avatar
Default RE: E320 will not start
climate / kickdown
was the car okay now? beside that relay was the fuel pump relay. they looked the same... was there is?
Old May 8, 2005 | 07:26 PM
MBraven's Avatar
I forgot to mension; it's a 92 model Estate car. No it is not OK.
There is only a small relay besides that I mentioned. When I said working all time I ment it's clappering all the time, then a break and the on again. On the other side of the battery, right side from front, it's a "silver" relay, with a plastic top (under is a fuse), what is that relay for.
Thanks for the answer so far.
MBraven
Old May 9, 2005 | 01:03 AM
MB/TECHMAN's Avatar
jump pins 5 and 7
Old May 9, 2005 | 02:54 AM
over voltage protection.
kindly state the first 6 vin number please.
Old May 9, 2005 | 12:38 PM
MBraven's Avatar
Hi again.
My numbers are:WDB1241061F200724
Observe: the car is rebuilt to a E320 from car with number: WDB1240921F24534
Hope this helps. The car is stil totaly dead, but the fuelpump is working, hven I turn on ignition, and stops after a few seconds, but no starting. Starter motor is running, no sounds of ignition.
Thanks in advance.
MBraven
Old May 9, 2005 | 11:51 PM
they convert the car from 5 cylinder diesel engine to 6 cylinder gasoline engine from station wagon!
must be a lot of job.
Old May 9, 2005 | 11:57 PM
what can i say now?
first check if there is a spark coming from the secondary ignition leads. you can try putting an external old sparkplug on it. don't do it if you are using pacemaker.
check the crankshaft position sensor. make sure the connector is not loose.
Old May 11, 2005 | 08:30 PM
  #9
MBraven's Avatar
Thank you so far.
Can you give me the details (data) on both cars?
In advance thank you.
MBraven
Old May 11, 2005 | 10:40 PM
  #10
VIN WDB1241061F200724
Model 250 D
Chassis 1241061F200724
Engine 602912 10 197474
Transmission 717413 01 971900
Order 0 1 555 46547
Approx. year 1991
Lights BOSCH
Wiper BOSCH
Dealer Norway (555)
Interior cloth medium red (067)
Paint
027 designo lcp 2 (green/blue) (ั 01.01.1978)
Options
211 automatic limited slip differential (ASD) (ั 01.07.1984)
rear axle with automatic limited slip differential (ASD)
236 special lamp switching - daytime running lamps (ั 01.04.1985)
special light wiring for Norway and Sweden
240 outside temperature indicator (ั 01.03.1982)
341 additional lamp (ั 01.09.1982)
563 front seats, left and right, reinforced (ั 01.04.1970)
572 front seat, right, with seat height adjustment; l.h.d. (ั 01.08.1975)
595 heat-insulating glass, windshield and side window panes, band filter
green heat-insulating glass, side windows and windscreen - tinted strip (not sl coupe-roof and chassis) (ั 01.02.1971 ะฟะพ 31.01.1996)
600 headlamp wiper/washer (ั 01.08.1971)
620 emission control system
vehicles with catalyst technique (ั 01.03.1985)
636 elimination of warning triangle (ั 01.03.1973)
673 high-capacity battery (ั 01.01.1964)
837 rubber mats on front floor and rear floor; with chassis, front only; with station wagon, including loading floor (ั 01.11.1969)
842 right front seat with folding backrest for partial body (ั 01.11.1976)
978 chassis special version (ั 01.01.1987)
VIN WDB1240921F245343
Model 320 TE
Chassis 1240921F245343
Engine 104992 10 000580
Transmission 717450 06 248797
Order 0 2 223 10591
Approx. year 1992
Lights HELLA
Wiper BOSCH
Dealer Darmstadt branch (223)
Interior leather black / anthracite (271)
Paint
481 bornite (blackberry) metallic (ั 01.01.1990 ะฟะพ 31.12.1996)
Options
244 sports seats, front (ั 01.07.1986)
260 elimination of model designation on rear lid (ั 01.05.1968)
281 trunk set, (280 SL)
steering wheel with sports design (390 mm dia.) and gearshift lever in leather trim (ั 01.05.1990)
steering wheel (390 mm) with sports design (ั 01.03.1989)
531 automatic antenna (ั 01.01.1963)
541 double roller blind used as luggage and passenger guard (ั 01.01.1980)
585 Behr air conditioner and electric window lifters (front doors) (ั 01.04.1970)
591 heat-insulating glass, all-around, heated rear window pane, (single-sheet safety glass), Germany
green heat-insulating glass all round, heated rear window, single pane safety glass - Germany (ั 01.01.1972)
653 sports chassis with 8-hole light alloy rims (ั 01.01.1990)
724 cargo anchorage (ั 01.04.1979)
751 Becker radio Grand Prix 2000 vk RDS (ั 01.06.1990 ะฟะพ 31.03.1994)
855 telephone TELE-AID, Nokia, D-net
873 seat heater for left and right front seats (ั 01.02.1984)
953 rotating emergeny flasher, central front (blue light)
sportline with 8-hole rim (consisting of codes 65/3, 244, 281) (ั 01.02.1991 ะฟะพ 30.09.1996)
