door locks, trunk and fuel door locked
Old May 28, 2008 | 02:00 PM
gaby7588's Avatar
Default door locks, trunk and fuel door locked
Mercedes 280 SE (EUROPEAN VERSION) 1985
It looks like the vaccum that activates the release of the door locks and trunk and fuel door stoped working. I has asked a couple of persons but they don't seem to know where they are located. The other thing is that the trunk key is missing and they are high security lock keys. What canI do to fix all that and how can can i get a repair mannual?
Old May 28, 2008 | 04:40 PM
carnut's Avatar
Default RE: door locks, trunk and fuel door locked
The vacuum pots are in the trunk for both. Try removing the back seat and locate the vacuum hoses going thru the trunk wall. Then with a tool called a "Mightyvac" pump vacuum into the lines. Hopefully the vacuum leak is towards the front of the car, not in the trunk. A tool supply store should stock some sort of hand held vacuum pump like the brand "Mightyvac". If the existing key is the master key, not the valet key, it should turn and unlock the trunk. Also look underhood by the brake booster where all the body vac. hoses are. Maybe a vacuum tee is unplugged?
S_benz
Nov 27, 2017 05:22 PM
rjm
Jul 12, 2007 06:42 PM
rjm
Jun 16, 2007 11:18 PM
rjm
Jun 16, 2007 02:28 PM
edwardwright
Jan 5, 2005 12:48 AM
