diagnostic code
Old Feb 24, 2008 | 12:18 PM
michael27's Avatar
Default diagnostic code
Also, I need to confirm these codes. They are, P201C, P2010, P0450. One more thing. If my BAS indicator light came on and my cruise control stoppd working at the same time, is it possible its a switch under the brake pedal?
Old Feb 25, 2008 | 01:27 AM
snanceki's Avatar
Default RE: diagnostic code
P2010 Injector circuit Cyl 10.
P0450 Evap loss system Pressure Sensor.
P201C Non standard convention.
However P0201 Injector circuit Cyl. 1
Bad brake light switch COULD cause BAS and CRUISE. Switch has two circuits. NO/NC.
Stuart
Old Feb 25, 2008 | 07:17 AM
michael27's Avatar
So th pressure sensor refered to is the one located on top of the fuel pump which needs to be totally replaced?
MsLarks230
Aug 7, 2012 03:17 AM
pguard
Dec 23, 2006 12:51 PM
joaohf
Aug 6, 2006 04:38 PM
wfhart
Mar 9, 2006 02:44 AM
iotiger
Dec 14, 2005 12:42 PM
