correct transmission fluid 300d
Originally Posted by tbailey
What is the recommended auto trans fluid for 82 300d turbo? Thanks
Here's the official list from Mercedes....BUT.......a lot of people, including myself, run synthetic fluids in the tranmissions. Some of the more popular choices are Mobil 1, Amsoil and Redline ATF's. Can't go wrond with any of them!!</P>
Castrol Dexron-III/Mercon ATF F-30341
Castrol Transmax M-22257 / 22096
Chevron ATF Dexron III F-30108 / 30159
Citgo Multi-Purpose ATF D-21571
Exxon Superflo ATF Dexron-III F-30111
Havoline ATF Mercon/Dexron-III F-30321
Pennzoil, ATF D-21380
Pennzoil, ATF F-30110
Quaker State Dexron-III/Mercon F-30161
Sunoco ATF Dexron-III/Mercon F-30176
Texaco ATF Mercon/Dexron-III F-30321
Unocal Multi-Purpose ATF D-22413 / 22431
Valvoline ATF Type D </P>
This should help. You can order the ATF at my site if you like. Have it drop shipped to your door.
Cost is 5.90/qt with Preferred Customer discount. Fluid Analysis is about 15.00 (for future checks, have it tested at the drain interval, these fluids are able to extend the drain period much longer than conventional fluids)
1982 MERCEDES BENZ 300D 3.0L 5-cyl VIN Code J 617.952 Diesel
FILTERS
Oil Filter......LF380
Air Filter......AF823
Fuel Filter......GF267
Fuel Filter......GF161
Fuel Filter Qualifier......Sec.
Fuel Filter Qualifier......Pri
BOSCH SPARK PLUGS
Plug......NA
Wire......NR
BOSCH WIPER BLADES
Driver side......B40920
Passenger side......B40920
Rear window......B40916
CHASSIS LUBRICATION
0 Fittings,0 Plugs
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......CI-4
SAE 15W-40 Synthetic Heavy Duty Diesel and Marine Motor Oil (AME)
Synthetic Blend 15W-40 Diesel Oil (PCO)
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil (HDD)
Grade 2......CH-4
Grade 3......CG-4
Grade 4......CF-4
-4 to 50°F......10W-30
Above 5°F......15W-40, 15W-50
Above -4°F......10W-40, 10W-50, 10W-60
All temps......5W-40, 5W-50
Below 23°F......5W-30
Automatic Transmission.....AF3
Synthetic Automatic Transmission Fluid (ATF)
Differential, Rear .....GL-5*[1]
90
Series 2000 Synthetic Gear Lube (TGR)
Synthetic Gear Lubes (AGR, AGL, AGT, ALU, AGO)
Fluids
Power Steering Fluid.....PS
Power Steering Fluid - Not Available Through Amsoil Click here for more information
Brake Fluid.....HBH
Hydraulic Brake Fluid, Extra Heavy-Duty - Not Available Through Amsoil Click here for more information
1. CS IDENTIFICATION: metal plate on rear of differential.
CAPACITIES
Engine, without filter..........8.0 quarts[1]
Cooling System, Initial Fill..........13.0 quarts
Automatic Transmission, Initial Fill..........6.6 quarts[2]
Automatic Transmission, Total Fill..........6.5 quarts
Differential, Rear..........2.3 pints
TORQUES
Oil Drain Plug.....20 ft-lbs
SERVICE INTERVAL
http://www.amsoil.com/lit/g1490.pdf
<img src=uploads/SyntheticsMan/3ZEF7_atf_qt_300pxh.JPG border="0"><edited><editID>SyntheticsMan</editID><editDate>37966.5973842593</editDate></edited>
FILTERS
BOSCH SPARK PLUGS
Plug......NA
Wire......NR
BOSCH WIPER BLADES
CHASSIS LUBRICATION
0 Fittings,0 Plugs
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......CI-4
Grade 2......CH-4
Grade 3......CG-4
Grade 4......CF-4
90
Fluids
Brake Fluid.....HBH
CAPACITIES
TORQUES
SERVICE INTERVAL
Matt_Clarke
Jan 12, 2004 01:39 AM
