Coolant Expansion Tank
Old Feb 17, 2005 | 02:54 AM
R129's Avatar
Default Coolant Expansion Tank
Mine has sprang a slow leak where the plastic tank meets the metal neck for the tank cap. Is this a common MB fault? Is it safe to drive the car in this condition?
Old Feb 17, 2005 | 03:30 AM
sleepwalker's Avatar
Default RE: Coolant Expansion Tank
replace the cap.
lack of pressure inside the cooling system will make the water boil and cause overheating.
Old Feb 17, 2005 | 05:56 AM
R129's Avatar
I replaced the cap but found that it's actually the tank neck (plastic with metal insert for the cap to latch on to) that's leaking so I ordered the newer (post 1996) expansion tank - the pre 1996 coolant tank is not available. Parts dealer said it's a common MB fault - probably reason they updated to the newer expansion tank.
Old Feb 17, 2005 | 04:47 PM
R129's Avatar
Hey Al, do you have any special procedure to replace the expansion tank? As it is connected to the radiator - do you have to flush the coolant? Any special connectors to worry about? A bit hesitant to do this myself as I have not seen the new tank and there could be additional/fewer connections.
Old Feb 17, 2005 | 10:17 PM
you only need to be careful of that overflow outlet which the hose #5 is attached. it can easily break and not replaceable.
if it's not very hot, i just remove it directly without flushing.
it's not that difficult replacing it because you got good visibility of everything from the top.
seems you really are restoring the car to it's "good as new" state?
Old Feb 18, 2005 | 06:57 AM
R129's Avatar
Thanks! What's this hose #5? Yes, that's the idea - to restore it to 'as new' and original condition.
Old Feb 18, 2005 | 07:38 AM
jeez, i forget to attach the [sm=smiley35.gif] image
i'll repost it next week.
sabado na kasi, at medyo pahinga (kahit na maghapon na walang ginagawa
Old Feb 18, 2005 | 07:42 PM
R129's Avatar
Ok thanks. the new tank is arriving next week.
Old Jun 14, 2005 | 06:40 AM
  #9
R129's Avatar
Hey Al, can you post the diagram for the R129 coolant expansion tank - specifically hose #5. Also, I noticed that there is another coolant tank behind the right fog lamp next to the horn? Is this some sort of overflow tank?
Old Jun 14, 2005 | 07:29 AM
  #10
welcome back!
tagal mong nawala ah
[IMG]local://upfiles/1/0B0BD5FD8A1C4D70BE2EACDD277E7B0A.jpg[/IMG]
