Compression Pressure
Old Nov 11, 2004 | 03:33 PM
R129's Avatar
Default Compression Pressure
Does anybody know the normal cylinder compression pressure for an R129 5.0L V8 in psi?
Old Nov 11, 2004 | 09:37 PM
sleepwalker's Avatar
Default RE: Compression Pressure
tolerance when new: 13.5 to 15.5 bar.
limit value is: 8.5 bar
permissible difference between individual cylinders: 1.5 bar
now, just convert it to PSI. maybe about roughly 14.5 psi to 1 bar.
Old Nov 11, 2004 | 10:32 PM
R129's Avatar
Maraming Salamat Sleepwalker!
I presume limit value of 8.5 Bar is lowest value permissible otherwise an overhaul is required? My 1994 R129 is reading 12 bar - is that normal?
Old Nov 11, 2004 | 11:23 PM
walang anuman. basta pag may kailangan ka, just post.
very normal and ideal. for as long as the deviation from one cylinder to another is not too far.
libbybapa
Jul 5, 2006 03:23 PM
rkpatt
Feb 6, 2006 09:47 AM
allan l
May 14, 2005 01:00 PM
big jesus
Mar 4, 2005 02:11 PM
gavinbr
Jan 5, 2005 10:54 PM
