codes p0446 and p0450
Old Dec 24, 2014 | 03:55 PM
Jim Erlichman's Avatar
Thumbs down codes p0446 and p0450
I have a 1999 E320 4matic. I keep getting these 2 codes. I have repaired 2 wires to the tank pressure valve due to excessive resistance. The purge vent valve was replaced and the power and signal wire to the pcm are good. I am confused because it will always would occur on the second start immediately. I thought this would only be activated under driving at higher speeds. I see no pump for the tank. I cant identify which line to the charcoal canister are the vacuum line. Any one have any ideas. How would I check the vacuum system to the canister as per the repair sheet. It meets all the voltage requirments.
Old Mar 15, 2016 | 12:36 PM
conleyhouse's Avatar
[QUOTE=Jim Erlichman;168125]I have a 1999 E320 4matic. I keep getting these 2 codes. I have repaired 2 wires to the tank pressure valve due to excessive resistance. The purge vent valve was replaced and the power and signal wire to the pcm are good. I am confused because it will always would occur on the second start immediately. I thought this would only be activated under driving at higher speeds. I see no pump for the tank. I cant identify which line to the charcoal canister are the vacuum line. Any one have any ideas. How would I check the vacuum system to the canister as per the repair sheet. It meets all the voltage requirments.[/QUOTE
Copy link into your browser this guy talks about replacing purge valve but will also point out vacuum lines.
coachgrowl
Apr 19, 2013 08:48 PM
tomw774
Aug 22, 2010 11:35 AM
Pverduzco
Aug 31, 2009 10:15 PM
svtguy08
Sep 21, 2006 05:02 AM
Fix_it
Mar 21, 2005 10:49 PM
