Cleaned DPF, now wont reset or run
I have a 2011 ML350 Bluetec Diesel. I took off the DPF to have it cleaned and after putting it back on, it will not run and I have the following codes that won’t reset:
· P2459 Permanent Particulate Filter Regeneration Frequency Bank 1
· P2458 Permanent Particulate Filter Regeneration Duration Bank 1
· P0299 Permanent Turbocharger/Supercharger A Underboost Condition
· P2463 Permanent Particulate Filter Restriction – Soot Accumulation Bank 1
Please let me know what I need to do to get this car running again.
Thanks in advance, Matt
Added 9/20/23
Any advice on this would be great.
I know to clear a permanent it needs to by driven, but right now it won't stay running. Just idles for 10 sec then a turbo squeal.
When I first changed the DPF out, I was able to drive it and then found the upper clamp was not tight (found there is a placement bump) but it ran and went into limp.
I placed the clamp on correctly, got .5 miles down the road and it quit completely.
Thinking of loosening the clamp again to see if I can get it to idle.
Is there a download that needs to take place or do I have deeper problems?
Thanks,
Matt
Added 9/20/23
Thanks,
Matt
