changing tranny fluid
yes, but i am considering that he have an automatic transmission. he must use a small funnel to fill it up from the transmission oil dipstick. the engine must be keep running while filling it. if it's a manual transmission, then its another story:
he must lift the car up to get access on that filler plug. of course you got two down there, and you must fill it on the upper one since the lower one is for draining.
be careful not to overfill it. it takes only 1.5 liters when drained (modified from 1.8 liters before).
