CD Changer
Old Aug 25, 2007 | 11:13 AM
milo's Avatar
Default CD Changer
I just purchased a cd changer throught E-bay and was told, later by a friend that worked on Mercedes that the radio has to be set-up or programmed to except a cd changer. Is this true and or can anyone help me.
Thanks E430 2000
Old Aug 25, 2007 | 04:48 PM
tric1's Avatar
Default RE: CD Changer
yes, the fiber optic ring will have to be rewired and then programed.
Old Aug 26, 2007 | 06:31 AM
milo's Avatar
Do you how this is done, or can you direct me to a site , Thanks
Old Aug 27, 2007 | 01:29 PM
milo's Avatar
When I purchased the Mercedes it looked like there was once a cd changer in the trunk well, will it still have to be programmed?
Old Aug 27, 2007 | 03:42 PM
uberwgn's Avatar
Milo, what CD changer did you buy? Be specfic.
I purchased a used Becker 6 disc changer off eBay a couple of weeks ago. Condition: unknown
After getting the correct adapter cable from Becker, I plugged the sucker in and life has been good since. Our '02 wagon did not have a CD changer previously and has never been programmed by the dealer AFAIK.
Some cars seem to need programming while others can get away without it.
Old Aug 28, 2007 | 07:07 AM
milo's Avatar
I purchased the model #3198
Old Aug 28, 2007 | 08:50 AM
uberwgn's Avatar
Milo, you may be lucky (luck me) and find it works after plugging it in. Nobody here can tell you with certainty. OTOH, if it doesn't work, it means a trip to the dealer for $100. I believe the dealer is the only one that can interface with the system to get it programmed when required.
Old Aug 30, 2007 | 05:23 PM
milo's Avatar
Just got the changer, problem, it lights up but will not eject the cartridge, also radio did not find changer, help.
Old Aug 31, 2007 | 06:51 PM
  #9
milo's Avatar
Not good, I just spent the last 8 hrs. trying to get this thing to eject. I happened to have anothr changer, from a jaguar which believe or not has the same internal parts, except board. I swapped boards and any necessary hardware, it still will not eject correctly. I give up they win. Ebay junk, dont buy unless you can return,$100 in the hole. Could be werse. I guess the only good thing is now I can answer any changer issue you may encounter. Any suggestions,I need a beer!!!
Old Aug 31, 2007 | 07:16 PM
  #10
uberwgn's Avatar
Milo, will you consider having it repaired?
