car won't unlock or start - 2002 C240
Old Oct 2, 2006 | 11:36 PM
dewk6600's Avatar
Default car won't unlock or start - 2002 C240
Electronic remote doesn't lock or unlock car (key battery is fine), can't turn key in the ignition, nothing works... the kicker - the car alarm goes off every so often and I can't turn it off. Any help would be appreciated.
Old Oct 3, 2006 | 12:20 AM
97dmsrS420's Avatar
Default RE: car won't unlock or start - 2002 C240
Sounds like a key code problem. Perhaps your key needs to be coded to the car. What are the particulars on your car. Yr/Make/Chassis/Eng. etc.
Old Jul 5, 2007 | 10:53 PM
GUESTO's Avatar
i'm new to the forum, and i have the same problem. i have a 2003 C32 AMG, can anyone please help?
Old Jul 6, 2007 | 03:06 PM
NAZ's Avatar
NAZ
YES I AM SORRY TO SAY THIS ITS GONNA BE YOUR EIS SWITCH AND IT CAN ONLY BE REPLACED BY MB THATS 1, IS YOUR CAR BATTERY OK IF OK CHECK FUSES NUM 57,51,30 THATS THE SUPPLY TO EIS YOU WILL FIND THE FUSE DESIGNATION ON RIGHT HAND SIDE OF YOUR DASH TO OPEN COVER WEDEGE A FLAT BLADE....LET ME NO HOW YOU GET ON...... IF YOU WANT THE SIREN DISCOUNTED REMOVE FUSE NUM 8 FROM TRUNK ITS ON YOUR LEFT SIDE ...GOOD LUCK NAZ B
WARRENFDS
Mar 6, 2021 07:37 PM
dewk6600
Dec 12, 2016 01:33 PM
Goldengirl1
Nov 8, 2012 07:28 PM
2004/240c
Jul 12, 2012 07:32 PM
jazharp
Aug 20, 2006 02:06 AM
