Bleed Power Steering Pump?
Old Jul 28, 2006 | 09:38 PM
jimmyjoe's Avatar
Default Bleed Power Steering Pump?
I am replacing the power steering pump on a 1997 C230. Can someone tell me how to bleed the pump?
Old Jul 28, 2006 | 10:36 PM
sleepwalker's Avatar
Default RE: Bleed Power Steering Pump?
it's self bleeding
Old Jul 29, 2006 | 03:06 PM
jimmyjoe's Avatar
Sleepwalker, maybe I should say flush out the system after I install the rebuilt power steering pump.
Old Jul 30, 2006 | 02:11 AM
just refill it.
no need for flushing. there's a recirculation strainer to stop larger foreign bodies that nay damage the O-rings or piston.
Old Aug 10, 2006 | 12:16 PM
jimmyjoe's Avatar
Hey Sleepwalker, I got the rebuilt power steering pump (LUK). It came without the top tank or the 2 mounting brackets. So I had to switch some parts. Everything went together real good. I did flush the system by leaving off the return line. The stuff that came out was kinda dirty looking. Then I jacked up the front end to get the wheels off the ground and turned the steering both ways several times with the engine running. This seemed to get the air out of the system. Everything works fine (no leaks). Here's a little tip. I drew a diagram of how the engine belt goes so I could put it back on.
The Big Dog!
May 14, 2008 07:23 PM
rcederblom
Nov 10, 2007 09:44 PM
mastalopak
May 28, 2007 03:17 PM
kanio
Sep 15, 2006 04:25 PM
Vorpal
Apr 13, 2006 12:14 AM
