TO ALL MB POWER PEOPLE -HELP PLEASE
Old Jun 9, 2006 | 11:50 PM
benz334's Avatar
Default TO ALL MB POWER PEOPLE -HELP PLEASE
1. WHERE CAN I FIND AC BLOWER REGULATOR IN MY E320 97?
2. AND MY EC LIGHT IS ON AND IS ANY OTHHER WAY TO REMOVE THIS LIGHT THAN STAR DIAGNOSTIC TOOL ?
3. NEED RADIO CODE OR QUESTION : IF I CAN INSTALL SOME OTHER BRAND -WOULD IT PLAY ?????
4. HOW CAN I CHECK MY 02 SENSORS ,WHERE IS SECONDARY AIR INJECTION RELAY,I GOT CODE P0410 -PLEASE ADVICE ME
5. I HAVE 38 PIN ADAPTER -WHAT SOFTWARE CAN USE TO DIAGNOSTIC - I TRY FEW AND NO CONNECTION OR NO READING -IS IT THERE A SPECIAL WAY TO DO IT????
IF YOU CAN HELP JUST WITH ONE -PLEASE DO SO -THANK YOU TO ALL POWERMAN THERE
Old Jun 10, 2006 | 04:01 AM
snanceki's Avatar
Default RE: TO ALL MB POWER PEOPLE -HELP PLEASE
2 Yes. Any good OBD scanner tool should be able to reset your CEL (Check Engine Light). However it may come back on straight away if certain faults exist. You seem to have a scanner since you refer to a code later.
3 You can fit a different head unit and it will interface with the rest of the system. remove the existing unit and you will see the types of connection you require. the MB unit is a good one so it may be better to get it unlocked. All you need is the serial number of the head unit and a MB garage, or other places on the internet will for a fee, unlock it by providing the required code.
4. You do not need STAR. P0140 is a secondary Air Injection Fault. does the air injection pump and valve work?
Once again a good scanner should be able to pick up the datastream from your diagnostics plug and display it as a real time graph etc. This will show whether the O2 sensors are working correctly. Max/Min volts and cycle speed. I use a DynoScan (from Auterra) on my Palm PDA but there are many available for PC's etc.
5. Unfortunately I not familiar with the 38 pin plug but the more recent trapezoidal shaped one. The info will be on the net somewhere. Its just a matter of finding which pins are the ones you need.
Hope this helps.
Stuart
Old Jun 10, 2006 | 03:13 PM
benz334's Avatar
thanks for answer
i know how to remove check engine light or code
i ment ec light on AC adjusting board ,since this light is on there is no cold ac just hot
DOES ANYONE KNOWS AFTER I WILL REPLACE AC COMPRESSOR ,DRYER,AC REGULATOR WILL I HAVE THE EC LIGHT STILL ON?????????????????????//
WILL MY AC WORK AGAIN WITHOUT GOING TO SERVICE
Old Jun 11, 2006 | 03:05 AM
snanceki's Avatar
When the EC light is ON (Economy) the A/C is turned OFF.
So it appears that when you press the switch you can't get the light to go off. Correct?
Have you checked the fuses?
Have you tried bridging the switch?
Old Jun 12, 2006 | 11:09 AM
benz334's Avatar
THANKS A MILION FOR GIVING ME A HOPE
YES THAT'S CORRECT MY ECONOMY LIGHT WONT GO OFF
AND AUTOMATICLY AC DOSNT WORK .
IS THERE ANY FUSE EXISTING FOR AC ??????
I TRY FIND IT AND I FOUND ONLY THREE SPOTS UNDER HOOD,SIDE DASHBOARD ,UNDER SEAT
PLEASE LET ME WHERE ELSE SHOULD I LOOK
ALSO I KNOW HOW TO BRIDGE IT BUT NEXT TO DRYER THERE IS TWO SWITCHES(PLUGS)TWO WIRES (SMALLER) OR WITH THREE WIRES(BIGGER)
OR YOU ARE THINKING ABOUT SWITCH SOMEWHERE ELSE
I WILL DO EVERYTHING WHATEVER YOU WILL ADVICE ME TO
DO YOU KNOW HOW DO I REMOVE THIS EC LIGHT ON AC BOARD????
Old Jun 12, 2006 | 11:32 PM
benz334's Avatar
ok
i checked all fuses, i did bridge switch next to drayer (two wires)
and my compressor still didn't kick in
also my ec light on ac board is still ON
Old Jun 13, 2006 | 02:42 AM
sleepwalker's Avatar
the compressor won't work whenever this light is on.
it's either it detects low refrigirant pressure, erratic evaporator temperature sensor reading, or faulty refrigirant temperature sensor.
it must be deleted using star diagnosis or hht.
Old Jun 13, 2006 | 09:19 AM
benz334's Avatar
only star diagnosis and hht ?
is it any other that will do it ?
where is the best place to buy star diagnosis ?
Old Jun 13, 2006 | 11:00 AM
  #9
hht is hand held tester for mercedes-benz
star diagnosis is diagnostic computer for mercedes-benz.
you can buy it from few sources for $25,000.
i can sell you one for $20,000.
you want one?
Old Jun 13, 2006 | 01:09 PM
  #10
benz334's Avatar
to sleepwalker,
yes i would like one ,but not for 20k
I CAN NOT SPEND MORE THAN 5K-COULD BE USED
thanks anyhow for offer
by the way i posted few post to you in the last weeks and haven,t see you for little while
1.is any chance for me to get radio code -I CAN HAVE ALL NUMBERS THAT YOU WILL ASK ME
2. i got code p0410 how do i know is it air pump or maybe something else -would give me couple clues how to find it out -what to check
3.if i replace my ac compressor,dryer,exp valve blower and regulator will my ac work or i still have to delete ec light ?
4.do i or should i change evaporator and condenser as well or is not nessesery and will not make any improvements?
5.i have check all fuses -my steering weel is not ajusting
6.let say i drive any speed more than 30 mph and when i am coming to stop it just last seconds before completly stops my transmission jerk,hit ,engage etc
is it trasmission mount or smething else ,when i drive the gears switch smooth -i got little vibration 50-80?????????
7.i lost power it takes me an hour 0-60 is code p0410 has to do on performance
8 and last one:what do you think about autoboss star scanner -is it also good and will i be able for exemple take ec code off????????AND WHAT WILL I BE ABLE TO DO NOT
COMPERING TO STAR DIAGNOSIS
THANK YOU VERY MUCH FOR ALL ANSWERS THAT YOU WILL COME UP FOR ME
I DONT KNOW HOW I WILL HELP YOU BACK FOR IT
ultrarevvin1
Jan 12, 2014 12:07 AM
FLmercedes
Apr 1, 2010 05:49 AM
MARIODRIVE
Nov 23, 2008 05:39 PM
jc240
Mar 7, 2007 03:42 PM
johnnywbo
Jul 27, 2006 08:14 PM
