AIr Conditioning
AIr Conditioning
1997 S320. After running with the A/C on heat starts coming out of the 2 side vents while cold air is coming out of the middle 2 vents. If I turn the car off and let it sit for a few minutes it is OK for a while then starts again. I have already replaced the control module as it wasn't working at all, but that didn't help. It was doing this before the control module quit. Any ideas?
RE: AIr Conditioning
Sounds like the vacuum motors that control the flaps directing air throught the vents. They are located under the dash. Contact George Murphy, Phone: 423-482-9175 9am to 5pm ET Fax 423-482-9175 anytime to get the diaphram repair kit. You can fix this cheap!!
trymonlam
04-09-2020 01:43 PM
