advice on cold start
Old Sep 14, 2006 | 02:00 PM
jagclassic2002's Avatar
Default advice on cold start
Can anyone help me i have a 190 1985 mercedes i am having problems with starting it
when it's cold it start's fine but when it's warm it's hard to start you have to give it a lot of acceleration
any help or advice would be much appreciated
thankyou
Old Sep 15, 2006 | 04:45 AM
snanceki's Avatar
Default RE: advice on cold start
From your symptoms it sounds as though your cold start device (extra injector like device) is operating when the engine is warm and thus giving you too much enrichment which you are addressing with wide open throttle. (More air, reduces mixture strength)
The cold start device is engine coolant temp operated.
Maybe the temp sensor for the cold start device is bad.
The cold start device has a connector on it. Does the car start more easily with this connector disconnected when the engine is hot and less easily when the engine is cold?
Not sure EXACTLY where your cold start device and associated temperature sensor are located on your car.
Stuart
crusier888
Oct 13, 2019 04:46 PM
Longhaily
Aug 2, 2008 07:28 PM
jbellia
Jul 16, 2008 08:39 AM
bluesky 2008
Apr 28, 2008 02:00 PM
jagclassic2002
Sep 15, 2006 03:54 PM
