ac
Old Jul 14, 2004 | 11:02 PM
tim's Avatar
tim
Default ac
I have a 92 300sd (140 style) with an a/c problem. The compressor will not kick on for the first 15 or 20 minutes in the morning, then blows ice cold the rest of the day. Any suggestions? Also, the outdoor temperature guage will read 66 degrees one minute, then the actual temp of 92 the next minute. Is this related to the climate control system?
Old Jul 15, 2004 | 01:46 AM
sleepwalker's Avatar
Default RE: ac
temperature related problem?
check the freon, maybe it's not enough. the pressure increases when the temperature does. one of the reason why it works when warm.
check the pressure switch and/or temperature sensor for ac.
check and replace the evaporator temperature sensor.
Old Jul 16, 2004 | 10:55 AM
ONEMBTEK's Avatar
Default RE: ac
Sleepwarker gives good advice.
The outside temp. gauge takes a few minutes to actually give the correct temp. if things are working properly. If it changes readings drastically while driving there may be problem. (Usually the sensor.)
---Larry---
Old Jul 16, 2004 | 11:06 AM
Default RE: ac
you really scared me larry, you nearly wrote sleepwanker. it's sleepwalker because i like the never fading song of johnny and santo... sleep walk.
http://www.sleep-walk.com/
it reminds me of something, my previous life maybe.
Old Jul 16, 2004 | 06:44 PM
Lugnut's Avatar
Default RE: ac
duwahhhh dah dododoooo duwah dah dahdah .....
Old Jul 17, 2004 | 12:47 AM
tim's Avatar
tim
Default RE: ac
Thanks for the help. I'll try to locate a temperature sensor for the a/c. Id this the one that also operates the outdoor temp reading?
Tim
Old Jul 17, 2004 | 03:58 AM
Default RE: ac
no, it is attached to the filter/drier/expansion tank or whatever you call it.
your outside temperature sensor can be seen on the front left side of the bumper, on that grill on lower part. looks like a stick of saratoga... only shorter.
Old Jul 17, 2004 | 09:25 AM
ONEMBTEK's Avatar
Default RE: ac
OOPS! Sorry about that Sleepwalker!
Still new around here and I'm not much of a typist!
Old Jul 17, 2004 | 01:01 PM
  #9
Default RE: ac
it's ok ONEMBTEK. we are all game here.
you do MB too? i hope we can share ideas and other techs.
cheers
