98 clk320 conductor replacement
My name is Robb and Im in Seattle. I replaced my conductor plate in a 722.6
trans, along with the coupler for the harness. I am getting hard engagement of forward and reverse
and the trans is in limp mode with a check engine light. Every think went together well but it does not
work now, atf level is good and proper for trans. Do I need to delete error codes? I do not own diagnostics
for this car, can you help?
the electrohydraulic valve unit and the electronic traction control unit must have a matching number.
try disconnecting/connecting the control unit to reset.
if the problem is no longer present, it not run in emergency mode.
zdzich
Aug 21, 2012 12:53 PM
inssane3gt
Sep 23, 2005 02:25 AM
