94 C289 Won't start when hot.
Old Sep 19, 2006 | 12:30 AM
florin c280's Avatar
Default 94 C289 Won't start when hot.
I have a '94 C280 and won't start when hot.
I replace the ignition switch, check trx switch, battery, starter and still have the same problem; after running about 15-20 min it won't start again, unless you let the engine cool down for about 20-40 min (depends on the outside temperature).
Note: if I "push" the starter it will start with no problem. That tells me that is an electrical problem (switch which will shut down the starting circuit)
Can anybody help with this issue?
Thank You!
Mr.47
Mar 5, 2014 04:58 AM
sveibl
May 28, 2008 11:06 PM
florin c280
Sep 20, 2006 11:02 PM
florin c280
Sep 19, 2006 11:35 AM
ivanpztorres
Jul 11, 2006 12:16 PM
