'94 C280 Instrument Cluster Woes
I bought a used 94 C280 with 93,000 miles. The speedometer doesn't work part of the time (always when you first leave in the morning, than 10 minutes in, it starts to work) & tonight none of the instrument will work, that is the temp, gas, tach & speedo. The outside temp and odometer and clock still function and the lights, but other than that it seems dead. Could this be a loose connection or is it common for the whole cluster to die? Thanks in advance.
I have a 1997 c230 also it does the same thing. The gauges just don't work sometimes.
I just bought it. I am wondering if I should have. It also is intermittently idling extremely rough. Sometimes it runs perfect for a few days then all the sudden it idles really rough
Let me know if you get it fixed please!
serge012374
12-28-2006 11:50 PM
rich121
10-07-2005 09:40 PM
94, benz, c280, cluster, dont, function, gauge, guages, instrament, instrument, intermittent, intermittently, mercedes, mercedz, panel, works
