92 300ce running poorly
Old Dec 23, 2005 | 10:57 PM
92300ce's Avatar
Default 92 300ce running poorly
I have a 92 300ce
It has 160k on it. A month or so ago it started idleing ruff and spuddering. I brought it in and the tech changed the fuel injectors fuel filter and some other things. It lasted a month or so and it started again.
Yesterday the car (After sitting for a few days) started up fine and after a couple of minutes it started spuddering and running ruff. It actually died out and would not restart. Then today, it started again ran beautiful for a minute of so and then idled ruff and started studdering again.
This is driving me crazy because it will idle great at a traffic light and when I take off it actually acts like I shut off the power and then it will kick back in. Also when it sits and idles it will run smooth and the all of a sudden it will hiccup then when I press the gas (in park) it shakes. Its almost like its losing power.
Some days it will run just fine! This is driving me nuts.
Any ideas?
Old Dec 24, 2005 | 12:45 AM
MB235's Avatar
Default RE: 92 300ce running poorly
I have the same thing going on with my 260 series. I am having the fuel filter changed in the morning but my mechanic also said to change the plugs and wires. He said with the Mercedes Line, when the fuel line goes bad, it does something to the firing of the plugs... I have no idea if this is true or not though, but just a suggestion. Wish me luck because I am changing in the morning... pretty embarassing having a Benz that stalls... I feel your pain.
Old Mar 7, 2006 | 06:09 PM
Oldpete's Avatar
Simple things first, a friend had the same problem years ago and it turned out to be a blocked fuel tank air vent causing a vacuum, he loosened the fuel filler cap and it worked fine, it's an easy one to try.
Rocker22
May 4, 2015 06:55 PM
PelicanParts.com
May 30, 2013 01:39 PM
tonka12
Feb 27, 2011 11:58 AM
Tom Gale
Mar 1, 2009 08:55 AM
kazacs
Aug 21, 2005 11:25 PM
