89 380 SEL
Old Nov 18, 2007 | 01:03 PM
Moocedes's Avatar
Default 89 380 SEL
Hello again. I also have a starting issue with the 89 380 SEL. It is VERY DIFFICULT to start. It cranks smoothly but you must do so for 12 to 20 seconds before it begins to start. When you let go of the ignition it dies. I have replace the fuel pump, filter, fuel distributor, plugs, and wires. I took it to the Benz house and for $600.00 the replaced the plugs and said it was good to go. They brought the car to me, already running, and I drove 100 miles home only to find the same issue the next day. If you crank, and crank, and crank it will eventually start, spew alot of exhaust emissions and then run quite well. Please help. Thanks in advance. Steve
Old Nov 19, 2007 | 06:27 PM
boomerfix's Avatar
Default RE: 89 380 SEL
have you checked the idle air control valve and hoses. . . emphasis on hoses ( own 89 300e same thing)
Old Nov 25, 2007 | 06:50 PM
Moocedes's Avatar
Thanks, will check it out.
Steve
northbeachfilms
Jul 28, 2009 02:24 PM
Brian M
Mar 26, 2006 06:02 PM
kaibeezy
Dec 26, 2005 08:26 PM
3jvj
Jul 8, 2005 02:44 PM
mjstef
Jan 25, 2004 09:40 PM
